Light turn off
Hello. I'm here for the first time, and greet the Polish
I have a question:
How do I turn off the light of day and traffic in my car?
Lights are turned on a non-stop when the engine is running.
I have a question:
You can turn off your day time running lights when the truck is on by pushing the dome over ride button located next to your headlight switch. Push it a few times quickly and it'll turn off the lights. they will stay off until you turn off your truck and when you turn it back on the lights will be back on again so you have to press the button again.
98 and up DRL
Remove the cover on the fuse box under the hood. Locate the DRL relay. Locate pin 86 on the relay. Bend the pin flat tight to bottom of relay. ( I recommend bending the pin incase you bend the wrong one, you can always straighten it). Then plug the realy back in and check to make sure the DRLs are off and you still have high beams.
this is what worked for me...am guessing you mean daytime running lights.
button mashing wont work on 99 and earlier i believe..at least not my 99
source:
http://www.s10forum.com/forum/f199/d...-how-to-14740/
source:
SubbinBlazer
May 24, 2013 12:56 PM
gturzer
Mar 25, 2013 05:00 PM
blazinloud
Nov 1, 2010 08:59 PM
