Lights/keys WARNING buzzer thing...
Old Feb 19, 2012 | 01:31 PM
97Beater4WD's Avatar
97Beater4WD is an unknown quantity at this point
Default Lights/keys WARNING buzzer thing...
Sorry about the title. I dunno what else to call it.. Recently the buzzer that tells you if you left ur keys in the ignition or left the headlights on has been STAYING ON while driving... And I can't figure out why.... I was wondering if there was a way to disable the buzzer... Until I can take it in to a dealer? Or if any of you have a solution it would be appreciated.
I'll try to get a video later today. It is super annoying
Old Feb 19, 2012 | 04:36 PM
Is the red seat belt warning light on? The switch in the seat belt receiver doesn't always cancel, causing the light and chime to come on.
Old Feb 19, 2012 | 05:16 PM
Nope..no lights what so ever....and it doesn't ding or chime...its just constantly on
Old Feb 23, 2012 | 08:02 PM
Ok. Now it on alll the time and i gotta go on a trip this weekend.... Does ANYONE know how i can disable this stupid thing...
Old Mar 27, 2013 | 09:23 AM
MKelley's Avatar
MKelley is on a distinguished road
I posted something yesterday about this. We have the same issue. Not sure how to get it to go away. Did you ever find a solution?
Old Mar 27, 2013 | 03:30 PM
EdC's Avatar
EdC
EdC is on a distinguished road
Can't you locate the chime and remove it?
Old Mar 30, 2013 | 08:48 PM
habafab's Avatar
habafab is on a distinguished road
drop the panel under the steering colum, on the right side of the colum youll see the chime, cut the wires to it and call it a day,also check the switches on the side of the dashboard that tells if your door is agar or not, im having an issue with those right now, my chime works when it should but the lights arent good luck hope this helps!
Old Mar 30, 2013 | 11:19 PM
cleburne red's Avatar
I'm having a similar problem. The plunger that the door pushes when it closes fell back through it's little hole into the dash somewhere. Most of the time it's ok, but I'll go over a bump, and the thing will go off! Usually a couple of well placed kicks will get it to stop. I've been to lazy to start taking panels off to find it. If the chime is under there, I'll yank it out. The blazer has to have the worst buzzer of any car I've driven!
fronkensteen_blazer
Aug 22, 2010 04:50 PM
xjimmyowner
Aug 8, 2010 09:51 PM
LittleT
Oct 4, 2007 09:32 AM
HillbillyDeluxe
Jul 16, 2007 02:01 PM
skhorse
May 2, 2007 04:49 PM
