Looking for help to tighten brake pedal (rattling brake pedal)
Old Sep 11, 2021 | 09:13 PM
reway's Avatar
reway is on a distinguished road
Default Looking for help to tighten brake pedal (rattling brake pedal)
I have a very loose brake pedal that will rattle when I go over bumps or even under normal driving sometimes, it’s driving me nuts and has recently gotten worse so I now will fix it. I have the dash panels off so I can see what’s going on. I can visually see that it is loose on the pivot bolt I’m just not sure how to tighten it. One side has no opening and the other side is all blocked by the footwell module. Am going crazy trying to figure this out if anyone has done this in the past and could share what they did that would be much appreciated!!
Old Sep 12, 2021 | 07:06 PM
Could you post some pictures?
Perhaps it is missing a bushing?
Old Sep 12, 2021 | 08:35 PM
reway's Avatar
Here is the best I could do. Looks like it still has that white plastic bushing in it, it has just worn with time it looks like.
File Type: mov
Old Sep 12, 2021 | 08:48 PM
reway's Avatar
I found a video of a guy pulling the pedal out on YouTube because he needed to drill a new hole into it and he shows that there is a small access hole right at the back on the right side at the very top of the steering column support and that’s how you access the bolt to take the pedal out. I tried for a good bit today just to get access to that bolt from below and it is definitely a no go with the dash on there’s just no space. The YouTube video is
and he takes the pedal off at the 11:00 mark. So I guess that’s it as I don’t think I will be taking the whole dash out just to fix my rattling brake pedal Attached is a video showing the rattle.
File Type: mov
ComputerNerdBD
13
Oct 24, 2017 09:59 AM
Pyrofanity
Oct 9, 2010 02:21 PM
Cheveevarer
Sep 6, 2010 05:16 AM
rknight
Mar 16, 2010 06:26 PM
Hoelgi
17
Oct 20, 2007 08:49 PM
