Loose Plenum
Old Apr 8, 2012 | 10:14 AM
Klturi421's Avatar
Klturi421 is on a distinguished road
Default Loose Plenum
I noticed this morning when looking under the hood, I noticed the bolts holding the plenum down were a little loose so i tightened them down.
Could that cause any problems? Misfire?
Old Apr 8, 2012 | 10:31 AM
50lb_cat's Avatar
Probably just hurting your throttle response and mpg. It might have been messin up the fuel to air ratio.
Old Apr 8, 2012 | 10:39 AM
50lb_cat's Avatar
Forgot to say it really depends on how "loose" they were. The torque required isn't very much.
Old Apr 8, 2012 | 10:43 AM
Klturi421's Avatar
I was able to give a full turn, on most, some I was even able to get 2 or 3 full turns before they started to resist a bit.
Old Apr 8, 2012 | 01:45 PM
chris015's Avatar
you have this blazer very long? Sounds like someone replaced the spider or something to do with the plenum and didnt tighten down the bolts.
Old Apr 8, 2012 | 10:59 PM
mrkevinmjr's Avatar
mrkevinmjr is on a distinguished road
hmmm u guys got me wnating to double check my work... which screw are we taklin about... the one attached to the rail ?
Old Apr 9, 2012 | 07:57 AM
Klturi421's Avatar
I have had the truck since 05 had a gasket replaced for the lower intake in 09. Have not replaced the spider...yet. I will be doing that job sometime soon.
ussexplorer
Apr 11, 2010 06:53 PM
bluiewest1
Oct 12, 2009 10:49 PM
Mick83002
Oct 7, 2009 09:41 PM
Blasir
Sep 6, 2006 08:11 PM
jaykeMURD
Jun 22, 2006 08:13 PM
