lost key
Old Dec 25, 2014 | 06:16 PM
popeyz's Avatar
popeyz is on a distinguished road
Default lost key
Ive lost the ignition key to my 1999 4wd 4dr LS Blazer. I cannot seem to find info on removal without the key . Any help would be greatly appreciated.....thanks...
Old Dec 26, 2014 | 08:55 AM
LannyL81's Avatar
Are you asking how to remove the ignition key cylinder out of the steering column?
If so, pretty easy. Just need to remove air bag, steering wheel, turn signal cam and then lock cylinder. Does require two special tools: steering wheel puller and lock plate depresser. Both available at auto parts stores.
Old Dec 26, 2014 | 09:46 AM
The ignition must be turned to the RUN position, then depress the cylinder lock tab with a small punch and slide the cylinder out. Without the key, you're screwed. Hammer, drill, punches, nasty words, etc, a real job. Easier, cheaper, and less damage to the vehicle to have a GM dealer make you a new key. Bring the entire 17 character VIN with you. Might need proof of ownership too.
Old Dec 26, 2014 | 11:47 AM
Bagherra's Avatar
Bagherra is on a distinguished road
Let's just hope this guy didn't steal the vehicle and come to this site to find out how to pop the cylinder....just saying....
Old Dec 26, 2014 | 03:37 PM
burned's Avatar
burned is on a distinguished road
Old Dec 26, 2014 | 04:15 PM
Yup, like that! He said it must be in the START position to remove the cylinder, some are start, some are run. You can look through the hole on top to see the tab, push it down, and slide the cylinder out. Great video, thanks Burned!
Old Dec 27, 2014 | 08:15 AM
LannyL81's Avatar
I did not know that the key was required...good to know. I was going from memory when I did my '81....but I may have forgotten about needing the key.
Blasted CRS!!!
Old Dec 27, 2014 | 03:11 PM
akaSPITTYBAYS's Avatar
akaSPITTYBAYS is on a distinguished road
GM parts counter, title, VIN and ID.
Not sure of the price. I know its cheap compared to the aggravation of pulling the cylinder and changing at least one door cylinder
Think you just need VIN and ID of the person that owns the car.
changeme20
Oct 24, 2020 02:12 AM
dougg01
Lifting Tech
19
Jan 21, 2010 02:48 PM
spedelbrock
20
Feb 27, 2009 01:04 PM
doozis
Aug 21, 2008 08:21 AM
rx7tturbo
Dec 4, 2004 05:01 AM
