loud clunk in right front
Old Dec 1, 2006 | 03:41 PM
chrissy's Avatar
chrissy is an unknown quantity at this point
Default loud clunk in right front
well when i turn hard left there seems to be a loud clunk in right front tire what would cause that i had the wheel bearing changed less than a year ago and ball joints and ideler arm what else could go on the front end
thanks for the help
Old Dec 1, 2006 | 04:05 PM
Jigg's Avatar
Jigg is an unknown quantity at this point
Default RE: loud clunk in right front
Ball joints i'd bet. Is it only when you go over a bump, or anytime?
Old Dec 1, 2006 | 08:23 PM
kornphlake's Avatar
kornphlake is an unknown quantity at this point
The most common seems to be ball joints, could be tie rod ends, sway bar bushings, control arm bushings, shocks, cv joints (if 4wd) or just about anything else in the front end. Take it back to the place where you had the work done last year and explain that the car is making noise and you think it might be a warranty issue. They should go through the front end and tell you that it's not the work they did (obviously) but they might tell you what is making the noise. That's alot easier than having all of us guess at what the problem is.
Old Dec 2, 2006 | 09:42 AM
rooster's Avatar
rooster is an unknown quantity at this point
my right side torsion bar mount cracked on me a while back. but i didnt find that untill some time later because to me the sound( loud clunk on turns espescially) seem to be in the front end, so finally when i went to make sure my cat was still tight(new) i pushed the bar and wouldn't you know it a cracked mount. took all bout 20 mins and 13. dollars to fix no more front end clunk.
choover82
Jan 14, 2012 01:02 PM
hulk
Jan 17, 2011 01:46 AM
01ice
Mar 24, 2010 08:30 PM
d666
Feb 20, 2009 09:39 PM
96jimmy4x4in
Oct 7, 2007 09:23 PM
