Lousy ride!
Old Aug 11, 2008 | 04:58 PM
edacsac's Avatar
edacsac is an unknown quantity at this point
Default Lousy ride!
I've had my '99 blazer 2 door 4x4 since it was new. First few years where great, but then started having a terrible ride. Thought I'd get shocks. Nope, shocks are fine, but you need $1400 worth of front end work. Accident waiting to happen. This was around 50k. I'm approaching 78k, and any bumbs on the road send the blazer into an epileptic fit, sometimes to the point I have to correct to avoid an accident. Verdict? Shocks are still good, just the way a blazer is. I'm getting kind of nervous lately though. A rough patch of road can make me almost loose control of the vehicle. It's bad.
Old Aug 11, 2008 | 08:53 PM
Default RE: Lousy ride!
Who keeps on telling you the shocks are good? If it rides like a boat, then the shocks mostlikely are not good. They can have poor rebound control and not leak. The valves inside do wear out over time.
What all did they replace in the front end for $1400? Better have replaced everything for that much. If not, they saw dollar signs when you walked in.
Old Aug 11, 2008 | 08:56 PM
WolfPack's Avatar
I would also make sure the sway bar is connected and secured properly. You've definitely got an issue....
Old Aug 11, 2008 | 11:20 PM
portcqb's Avatar
portcqb is an unknown quantity at this point
It sounds like you have really worn out shocks and/or a broken front sway bar or links for it. Most things say shocks should be replaced by 60k, some even say 30k. If those are stock even though they look ok they probably dont move well. One of my front ones before I changed them would get stuck when compressed to a certain point and would only release when force was applied again.
Old Aug 13, 2008 | 10:07 PM
Karnyboy92's Avatar
Karnyboy92 is an unknown quantity at this point
my friend had the same problem on his cougar it would hit a bump and go watever way it would feel like....im guessing its a sway bar or some front end assembally
Hernandez_2007
Engine & Internal
Mar 1, 2011 08:45 PM
danmiranda
Jan 11, 2010 07:17 AM
tjone9
Suspension Tech
Oct 6, 2005 12:40 AM
m00nwater
Mar 30, 2005 11:34 PM
zero psi
Dec 4, 2004 10:56 PM
