Low coolant temperature indication
Old Jan 10, 2010 | 10:59 AM
1998ZR2's Avatar
1998ZR2 is on a distinguished road
could be the fan clutch has seized.
Old Jan 10, 2010 | 08:43 PM
moldeck's Avatar
moldeck is on a distinguished road
What is the best way to get all the air out of the colant system? I get a gurgle when I speed up sometimes and I am guessing i am low on colant in the radiator/engin.
Do I just keep squeezing the upper hose untill I can not get any more colant in?
Old Jan 13, 2010 | 08:28 AM
dleonfc0's Avatar
dleonfc0 is on a distinguished road
Default low coolant temp
but if the fan clutch seized up would the fan still run...cause since its always running that would make perfect sense....meaning it never lets the engine get up to operating temp, but i figured if the clutch seized the fan wouldn't run at all, but i'm probably wrong...in fact i hope im wrong, because that would be an easy fix....and i'm about over this truck
Old Jan 13, 2010 | 10:03 AM
reytx1's Avatar
reytx1 is on a distinguished road
Originally Posted by dleonfc0
hey guys i have the exact same problem...the SES light came on, drove down to autozone to get the code, did a little research replaced the sensor and the thermostat...totalling $20...no biggie...and now a week or so later SES light comes on again and drove back to autozone and its the same code...low collant temp? any thoughts?
...also just to add the temp gauge never gets to operating temp...only gets just a notch or two above zero, but ever since the outside air temps have dropped its been like that, not the SES light, but just the gauge not getting up to normal temp...
..also if it matters...2004 ZR-2 4.3
How many degrees is the new thermostat rated for? Having one that opens at lower temperatures will keep your truck from ever getting to operating temerature.
Old Jan 13, 2010 | 11:14 AM
terry s's Avatar
terry s is on a distinguished road
I believe the thermostat is rated at 195 degrees. Having the fan clutch locked up and running direct should have no significant effect on the engine coming up to operating temperature.
Old Jan 13, 2010 | 07:20 PM
1998ZR2's Avatar
does the temp gauge rise and fall or does it stay constant? is the new thermostat a fail safe? ive heard of those locking open on the first run.
Carl@gmail
Feb 1, 2015 03:20 PM
ashapos
Sep 16, 2010 11:03 PM
rlbates60
Aug 25, 2010 12:59 PM
Optimus
Jul 10, 2008 09:24 PM
truesmack
Jun 24, 2008 11:56 AM
