Low MPG and Rough Idle after friend ****ed up car
So my buddy and I were off-roading with my 2003 ZR2 and we got a little stuck. After calling for help my buddy's dad came by with his truck and chained us up and tried pulling my car out. I let my friend try to guide the car out, but he stayed revving it at like 5k for about 15 seconds and pieces of burning metal started shooting out of my tailpipe. I yelled at him to stop and all was well. Once I get home, I realize that the vehicle is running rough at idle, but is fine when under load/power. I drove around a bit, and I swear to god I lost an eighth of a tank after driving down 2 miles with a little aggressive acceleration. Well, 2 months later and I still cant find the god damn problem. The injectors/ Fuel Pressure Regulator passed the leak down test, the intake gasket was replaced recently, MAF is clean, TPS is good, IAC valve is good, entire exhaust system is new, and the air/fuel filter is also new. I was thinking about putting a 5.7 in her soon, but I would really like to figure out what this problem is first. Burnt valves maybe? Any suggestions?
If you attempt a 5.7 swap on a second gen blazer, use the vortec 5.7 and retain the fuel injection and PCM. Otherwise it will be a big hack job. Doesn't NY emissions testing prevent a lot of engine swaps. Also could be a problem if engine is older than the vehicle, and a 2003 might require a LS engine swap if it matters in your state. Fortunately for me I live in Indiana! We don't have vehicle inspections here.
Time to do a compression check and/or leak down test on all cylinders. Start engine, pull fuel pump fuse, let engine die and then get started pulling all the plugs out. Also place something to hold throttle body open before doing compression check, not needed for leak-down test.
Just a suggestion.
Just a suggestion.
chevywoman15
08-01-2014 06:07 PM
BlackBeauty43
11-20-2013 07:57 PM
avelate63
06-22-2012 04:40 PM
lost113
12-11-2011 06:08 AM
PubEnemy
08-01-2011 08:27 AM
