Low oil pressure problem
I wouldn't call it "rare", probably several million of them were built. It might be a rare request due to techs being unaware of it and what it does. The 4.3L has been around since 1985 and it's a V6 version of the V8 350. Same bore and stroke, and I wouldn't be surprised if the 350 uses the same valve.
The valve is pressed into the engine block. Pressurized oil leaves the oil pump, and if the valve is stuck open, a certain percentage of oil is directed, (bypassed) right back into the oil pan. This causes oil pressure, (and volume) to the engine bearings, to decrease. If the valve sticks closed, oil pressure will rise and explode the oil filter and/or cooler lines. Think of the valve as an oil pressure regulator, it keeps oil pressure from getting too high
If the oil filter is remote mounted, (under the radiator) there is a normally closed bypass valve in the remote mount. If/when the oil filter becomes clogged, the valve opens. Oil is then circulated through the engine without filtration. When this valve opens, oil pressure is not affected to the point where you'd notice a drop. GM part #25013767.
The other bypass valve is pressed into the engine block, (requires oil filter adapter removal). Its purpose is to prevent the oil from over pressurizing and blowing the oil filter apart. The valve is normally closed, but if it sticks open due to a weak or broken spring, sludge build up, etc, pressurized oil is directed back into the oil pan so the oil filter will not blow apart. As a result, oil pressure drops and oil starvation to the engine bearings will occur. GM part #25014006.
Damn...if I didn't know any better, I think you know what you're talking about...lol
