Low power/no acceleration after warmed up
Old Aug 10, 2013 | 07:12 PM
  #31
spittybays
Guest
Posts: n/a
If its a K&N oiled filter throw it the F out. The oil screws with the MAF. Put in stock and clean the MAF. That's kind of what I meant by "special". K&N's are specially made to screw up MAF sensors. Bet you will be fine after.
Old Aug 10, 2013 | 08:17 PM
  #32
tondox1's Avatar
tondox1 is on a distinguished road
No, it's stock. Not an oiled filter
But I do regret to inform the masses, i drove around just now after having the car sit for a few hrs (MAF still UNplugged) and the symptom came right back.
I'll still check the sensor with a DMM, but back to the drawing board nonetheless.
Old Aug 10, 2013 | 09:08 PM
  #33
burned's Avatar
burned is on a distinguished road
Get yourself a scanner and quit the guessing game. If you have a smartphone or tablet you can use a program called Torque along with a cheap Chinese scanner off of DX.com or Amazon.
Old Aug 10, 2013 | 10:18 PM
  #34
AndrewO1991's Avatar
AndrewO1991 is on a distinguished road
have we ruled out clogged cat?
Old Aug 10, 2013 | 10:34 PM
  #35
tondox1's Avatar
Yes. I installed new muffler/ direct fit cat/ 3 Oxygen sensors (ACDelco) just a few days ago.
And I just ordered an OBD2 dongle as "burned" had recently suggested.
Im researching Fuel Pressure Regulator and the Fuel injectors right now. I have a feeling it may be the faulty spider assembly.
(I hit 160,000 miles today)
Old Aug 11, 2013 | 10:16 AM
  #36
fuel regulator is all about leakdown, your test results earlier dont show me any signs of immediate problems. Its clearly not 100% but driveability shouldn't suffer. But if a poppet is sticking it "could" cause a problem but you would surely get a misfire code with that. I would get a scan tool with data readouts form the sensor and monitor it when it's messing up to see what is out of whack
Old Aug 11, 2013 | 12:14 PM
  #37
tondox1's Avatar
Yeah, I did just order a wireless OBD2 dongle last night and should be able to mess with it when it get here in a week or so. I also have a can of seafoam im gonna use and see how it runs.
Old Aug 14, 2013 | 09:48 PM
  #38
99blazerdog's Avatar
99blazerdog is on a distinguished road
I unplugged my MAF and it runs way better. But my check engine light came on. I plugged it back in and it's still on. Would the MAF have caused this? Or is it something else?
Old Aug 15, 2013 | 06:11 AM
  #39
jimspahr@msn.com's Avatar
I think the check engine light 'is still on' because it was set and needs to be 'erased' from the PCM memory. Some are automatically erased after so many restarts without the DTC showing up.
Old Aug 17, 2013 | 04:02 PM
  #40
Captain Spaulding's Avatar
Captain Spaulding is on a distinguished road
my 95 blazer was doing the exact same things...sluggish/no power after warmed up loud fan noise. i replaced fuel filter sensor after sensor still wasnt fixed i got frustrated and sent it to a mechanic friend of mine to look at he adjusted the timing after that the truck runs great no issues no loud fan noise has great power and much better gas mileage im not much of a mechanic but whatever he did to the timing sure fixed my issues that are the same your having hope this helps
