Lower radiator hose
Old Oct 24, 2019 | 11:12 AM
WillyB's Avatar
WillyB is on a distinguished road
Default Lower radiator hose
Good morning!
Checking fluids this morning and noticed lower rad hose sucked flat in the center between radiator and water pump? What the hell does that mean? Thanks. Mind you, new hose about 2 months ago when I replaced water pump
Old Oct 24, 2019 | 12:05 PM
You may need a new radiator cap. As the engine cools, it's supposed to suck coolant back from the reservoir. It looks like your cap is not allowing it to do so.
Old Oct 24, 2019 | 07:09 PM
eshaw's Avatar
I've heard of this but never seen it, pretty blatant.
Old Oct 25, 2019 | 05:08 PM
Mine did that when my water pump seized... and when the radiator clogged... try flushing it out, I lucked out and got an almost new one from the yard...
Edit: I did notice the new pump you installed.
Hows the fluid color?
Old Oct 26, 2019 | 04:20 AM
When cooling, the contracting coolant leaves a depression in the system. It should pull liquid from the expansion reservoir as stated before through the cap.
To avoid the collapsing of the coolant hoses, most have a spiral spring style insert in order not to collapse but to draw from the expansion reservoir.
puttster
25
Jun 22, 2021 08:30 AM
karlb
15
Jun 4, 2016 09:21 PM
HamToast
Dec 27, 2012 08:37 PM
fwupow
Mar 13, 2012 01:01 AM
96Ls4Dr
Feb 13, 2006 02:47 AM
