Lowering Kit
Lowering Kit
I'm looking into lowering my blazer. Does this kit include everything I'll need.http://www.andysautosport.com/chevro...r00037788.html. Any advice ? Anyone have any pics of a 3 inch drop ?
RE: Lowering Kit
I think that kit is for an S-10. Blazer's have sealed front hubs so the spindles shown will not work. 2" drop spindles for a Blazer run about $200-$300.
RE: Lowering Kit
Ok you can use that kit the only things you will need to purchase to go with that kit and I will list for you:
all these parts are from a 99 s-10 pickup this is what i converted mine over to for those spindles:
rotors with bearings
calipers
pads
brake line (make sure you get the one with the bigger oppening to fit from your hardline to you caliper ) the soft line is what your replacing
that is all you will need to swap over your front to use that kit!! suggestion hit up a junkyard for the list I gave you I did and I saved a ton of money!!
calipers
pads
vagnozzi
05-05-2007 10:32 AM
