In the market
In the market
Hello everyone. First off, I wanted to say that you have a great forum here with lots of good and helpful information.
I am currently looking at purchasing a 98 Blazer LT, 4DR, 4x4, I'm wondering what I should be looking for that is or can be a serious problem. Also, how well do these trucks do with occassional 4 wheeling and how hard are they to get and install a lift kit?
Thank you for the help and/or advice. I look forward to getting a lot more out of this forum
lift = easy to moderate for quick lift (+2" torsion bar crank, +2 rear lift shackles, and a 2" body lift will run you less than $350 and will allow you to fit 31x10.5 tires) and easy to find, a little harder to install for suspension lift
if you are serious about knowing what to look for.....
this is a LOT of bitching but paints a pretty good pic of what to point your eyes at as far as common to the Blazer stuff goes. you should check re-check and the re-double-check the 4wd!!! also in addition to checking out all of the normal stuff in any used vehicle, make sure your rear end is still a locking diff and not a broken open locking diff (read up on g80 rear diff)
enjoy
enjoy
not all blazers have em, but they are common as they were the bread and butter of GM's light duty rear diffs for a few decades. look in the glove box: there is a sticker if one of the codes is g80, you have a locking diff. now go out and spin the tires on some wet grass or leaves etc. if it spins like hell, then lounges a bit, and suddenly gets sweet sweet traction, you're in business.
