Metal sound after start up
Old Dec 7, 2014 | 12:56 PM
Radio Doc's Avatar
Radio Doc is on a distinguished road
My starter on a 2000 was sticking, keeping the starter engaged to the flex plate.
Sounds awful. Turning the ignition off , and the starter keeps cranking.
Reving up the engine sometimes makes the bendix disengage. *PROBABLY* there are bad contacts in the bendix that sometimes weld shut .
Old Dec 21, 2014 | 05:44 PM
kmartin's Avatar
kmartin is an unknown quantity at this point
Ok, back again. I getting to be sure its the alternator. I took belt off and turned some pulleys and the alternator did give a little noise, but still spun freely. Will the bearings cease up on me someday if I let it go, or will it just get worse and worse? I am looking to take a trip about 300 miles away from home. Do you think I will be ok or should I replace it? Should I replace the belt, tensioner, and pulley with it too? Or just wasting money?
Old Dec 21, 2014 | 06:47 PM
Alternator bushings/bearings can seize, sometimes without any notice. Who knows though, they might go for a long time making noise. Typically the tensioner, belt & idler pulley are good for 100K miles, after that, you're on borrowed time
Old Dec 26, 2014 | 04:17 PM
kmartin's Avatar
Originally Posted by Captain Hook
With all of this sub-zero temperature lately, it could be the starter drive is not retracting after the starter is disengaged. Without putting an ear on it, tough to diagnose.
Yes, Captain Hook, it actually was the starter drive not retracting. The retracting spring was not working. The TP roll can now head down the toilet. It only helped me misdiagnosed the problem. I now am now pissed. First at me for misdiagnosing the problem. I replaced the alternator, and with that the belt, and the 2 pulleys. I thought it was the alternator, because it seemed the noise came from there and I took the belt off and it squeaked a little when turned by hand. The belt was on since I had it so it was probably original. Being its over 11 years and over 107,000 miles it needed that anyways. When I first said something in 2009, it was a year that I put the last starter on and I could had it replaced under warranty. The parts store was at least willing to give me 15% off, but I went to an auto electric shop who replaced it for me today, and they were very reasonable. This as been an expensive year for the Blazer and I hope that next year will be better.
Old Dec 27, 2014 | 11:23 AM
Bagherra's Avatar
Bagherra is on a distinguished road
Sorta went thru same thing a few weeks ago....
Something was squealing and I was convinced it was the alternator or compressor. Removed belt and was ready to start replacing both. My neighbor (old car mech) came over and said try replacing the belt since its the cheapest. Didn't think belt was bad cuz it looked "brand new". $35 later, no more noise.
So glad I didn't spend $$ that didn't need to spent.
Old Dec 27, 2014 | 02:58 PM
kmartin's Avatar
At least you made a whole lot better than I did. And the replacement was a lot cheaper. I thought it had to be the alternator, because I took the belt off and spun the alternator by hand and it squeaked a little. The belt needed replacement anyways, and I did the usual idler pulley and belt tensioner with that. Over 107,000 miles and over 11 years on the belt. I wouldn't call that part waste.
ComputerNerdBD
Feb 29, 2012 08:09 PM
blazinloud
24
Oct 1, 2011 05:33 PM
cjh
May 15, 2010 09:06 PM
harryjoe21
18
Mar 11, 2010 08:00 PM
ESKYMOPACK
14
Mar 27, 2009 09:42 AM
