MGP issue
Old May 11, 2011 | 02:00 PM
drbandkgb's Avatar
drbandkgb is on a distinguished road
Default MGP issue
We bought a 2003 2wd Blazer with 60k on it from my wifes mom...
This thing seems to get about 200 mile between fill ups..
Im not expecting this thing to AVG 20 mpg but.. Seems really low to me...
Any tips to look for.. Im new to the Blazers.. (Not to Forums)
Thanks guys and Gals
Old May 11, 2011 | 02:05 PM
There are TONS of threads on how to restore/improve your miles per gallon. The search feature can help you find them.
But really, you have to know where you are now. What is your actual miles per gallon? Stating that you get 200 miles to a fill up really doesn't mean anything without knowing how many gallons you use in those 200 miles. And you know what they say about assuming...
Old May 11, 2011 | 08:31 PM
drbandkgb's Avatar
Well I did use the search function.. But when you have 50 things it could be...
I need to narrow it down a little.. And knowing how a good forum can be.. I figured it might be a common issue..
Is there any common issues that may need to be looked at...
Im AVG 10 miles per on a 19 gallon fill up @ 200 miles
Old May 11, 2011 | 09:13 PM
Tune up? Dirty MAF? Dirty EGR? Vacuum leak? The basics really and pretty much some of the first suggestions found in every thread I could find in a quick search. There's even DIY threads on the middle two.
Did you try any of those "50 things"? What have you tried? Any codes?
Old May 11, 2011 | 09:36 PM
drbandkgb's Avatar
I havent yet because I wanted to see if there were a few common issues before anything else.. That would explain why Im here... Most boards are very friendly.. guess this isnt one of them..
Most models have some common problem.. which is why I asked if there were any tips..
Something to look for.. I guess I could have searched for hours.. But thought some one could point me in the direction
Old May 11, 2011 | 09:43 PM
warthogdriver's Avatar
sorry to say but thats about what i get...
i avg 17 on highway and about 13 in city....welcome to blazerdom.
and i have to say this is a friendly forum....its just sometimes a squirrel has to dig to find that nut.
Old May 12, 2011 | 12:27 AM
rob44_90's Avatar
rob44_90 is on a distinguished road
Kyle (aka swartlkk) is just trying to tell ya that you probably don't have a problem that someone else hasn't posted about before, so no need to take offense. This is a common problem, but what causes the problem varies. I would check all fluid levels, check tire pressure (should be 32 psi), clean or replace air filter, change oil and filter (IMO use a WIX filter and Valvoline Full Synthetic oil), maybe spark plugs and wires need to be replaced, fuel filter could be clogged, EGR valve and MAF sensor may need to be cleaned, etc.... just about anything could make your fuel efficiency low. Sounds to me like it just needs a full tune up.
Old May 13, 2011 | 05:46 PM
drbandkgb's Avatar
Thanks guys... It has a new air filter.. Only 60k on the spark plugs.. So maybe one is bad..
Ill try cleaning the MAF.. but If I do the math this is getting 10mpg.. I seen new its rated at 15 to 19.. I know from dealing with Nissan Xterra's some times there are common issues that can be fixed to help bring the MPG back to spec..
PS I did try searching.. but its a wide category...
Looks like plugs wires are in my future
brian79z
32
Feb 23, 2015 07:13 PM
99bblazer99
Jun 15, 2013 08:38 PM
J.R. Clay
Mar 16, 2011 12:33 AM
extreme
Jan 5, 2010 07:29 AM
