This might be a common problem with taillights on Blazer S10
This might be old news but i post it if this can help anybody
On my 2000 Blazer ZR2 the the left taillight did not work properly
When I stepped on the brake pedal the brake light did not come on and the taillight stopped working/the light bulb for the taillight went dead
I figured that this was a ground problem so i cut the ground wire goint to the taillight/brakelight socket holder and wired the ground straight to ground and that made the taillight and brake light work as it is supposed to do
I have a spare light bulb holder for the taillight/brakelight so i checked out how it is put together and after looking at the socket holder i can say that there is no reason to cut any wires like i did.
If your taillights does not work as they are supposed to just take off the taillight and simply pull the ground wire out because the only thing that hold the wire in place is just a little "hook"
The problem on my car was that the ground wire contact surface in the socket holder was corroded and dirty so all i had to do was to clean it
If i had done this the first time i would not have had to cut the ground wire and also solder the wire ends back together
On the first picture to the left you can see the taillight and socket holder.
You have to pry off the blue plastic before pulling the ground wire straight out
On the right side picture you can see the "hook" that usual are corroded and dirty that you need to clean to fix the taillight problem
The "hook" on the wire is what holds the wire in place on the socket holder on both for ground, positive
So if you have any problems with the taillights i would clean the hooks that goes into the light bulb socket holder and push it back in
You might have to use a little screwdriver to get the "hook" at the end of the wires back in after cleaning
Remember to put the sealing you can see on the picture to the righ back into the socket holder and also put the blue plastic clip back on
ussexplorer
05-22-2011 09:09 PM
Blasir
08-17-2008 07:46 AM
epitaphoftwilight
04-05-2007 03:18 AM
