Mis-Fire P0304
OK so after several weeks of having loping idle and multiple codes for MAF MAP IAT and diagnosing troubles as wire connections and bad sensors finally got my 98 running, somewhat. Now I'm getting consistent P0304 code and poor mileage, fuel pressure test runs consistently at 62PSI even after 15 minutes after shut down. Replaced a couple sensors which helped with idle and running but still erratic then smooths out, then erratic RPM again with stumbling almost to point of stall. On a side note I also notice my auto door locks engaging randomly, is it possible to be BCM or ECM related from bad ground? Any help appreciated
Well that is a cylinder 4 misfire code, should be pretty straight forward to figure out. Cap, sparkplug wire, plug, loose plug, bad injector or leaking valve, in good to bad order. I had the same issues one time and hunted for a week, it was a loose plug LOL. This is all to do with cylinder 4
cjmor1804
09-14-2009 02:46 PM
