Misfire
Old Sep 19, 2008 | 02:08 PM
Hawaii's Avatar
Hawaii is an unknown quantity at this point
Default Misfire
I am new to this forum and from what I see it seems very helpful. I have a 1995 S10 Blazer 4.3 (Vin W)4x4. Six months ago it started hesitating on acceleration. The egr code came on and I took it out and cleaned it. It ran great until recently. It had the same symptoms so I went ahead and replaced the egr completely. This did not fix the problem. I have now replaced the plugs, wires, cap and rotor button. I started to replace things because the vehicle won't code out since I had it cleared. The last reading was multiple misfire. I replaced the coil, throttle position sensor and eletronic control module. The entire fuel system was replaced a year ago, so I really believe it is in the egnition system. Any suggestins would be greatly appreciated.
Old Sep 19, 2008 | 02:29 PM
rriddle3's Avatar
Default RE: Misfire
ORIGINAL: Hawaii
The dreaded 'multiple misfire' code. Use the search function for 'PO300' and see if the info you find will help. Let us know.
Old Sep 19, 2008 | 06:21 PM
Peru Motors's Avatar
Peru Motors is an unknown quantity at this point
Default RE: Misfire
just for *(@#$& and giggles, I would put a fuel pressure gauge on it and see if all is ok. If there is any question on what you find-report back to us all! JP[>:] PS may be ignition but this is an easy check and will eliminate pump injectors and the like!
rrk03300
Nov 15, 2012 10:29 PM
01extreme
Jun 7, 2006 01:48 PM
PhatKat
Mar 30, 2006 07:13 PM
wythel
27
Jan 30, 2006 02:04 AM
wolfe1967
Aug 29, 2005 12:27 AM
