Misfire cylinder 3 tear down pictures MPFI Already?
Old Jul 14, 2011 | 12:30 PM
cbierniat's Avatar
cbierniat is on a distinguished road
Default Misfire cylinder 3 tear down pictures MPFI Already?
After being fed up with 7 mpg, I decided to go ahead and replace my what thought to be SCFI but appears to be the MPFI? Below are some pics. You can see in the second picture there's a clean area... would this be where the unit could have been leaking?
Now question should I replace whole unit or just the one injector/line?
this is the updated version correct?
CIMG0221.jpg picture by Chad_Bierniat - Photobucket
Signs of gas leak here?
http://i1210.photobucket.com/albums/...CIMG0222-1.jpg
Old Jul 14, 2011 | 04:21 PM
That doesn't look like a fuel leak. Besides, the intake ports in the lower intake near that cleaner area are for cylinder 4 (port just ahead of the 3 in the LIM) and cylinder 6 (the port just behind the 5 in the LIM).
It could have been a bad injector for cylinder #3, ignition component problem, a valve issue, or other problem affecting the compression on that cylinder.
Old Jul 15, 2011 | 03:39 PM
cbierniat's Avatar
Well I replaced the whole unit and it seemed to fix the misfire problem. No more CEL or rough idle.
Old Jul 15, 2011 | 03:40 PM
Must have been a bad injector on #3. Glad you were able to fix it!
Old Jul 15, 2011 | 03:55 PM
Senshi09's Avatar
Senshi09 is on a distinguished road
how much did that cost you? Did you get a new system or one from a junk yard?
Figure since I changed my gaskets may as well get those changed now to. Completely rebuild the top end you know.
Old Jul 16, 2011 | 01:32 PM
cbierniat's Avatar
I replaced whole unit and cost $230 from Autozone. The brand name is GP Sorensen. 200 miles and so far so good. Don't forget to plug your intake manifold ports with towels to prevent anything from being dropped into it as soon as you remove the upper plenum. If you have a the right tools I would advise you to remove the gas lines at the firewall. It would give you a lot more room to play... I didn't so it's doable just more difficult. I believe its a 5/8
Gp Sorensen/Fuel Injector (800-1512N) | 2000 Oldsmobile Bravada AWD 6 Cylinders W 4.3L SFI | AutoZone.com
Old Jul 18, 2011 | 11:34 AM
pheaton's Avatar
pheaton is on a distinguished road
I'm glad to hear that worked out for you. I tried to change my SFI to a MPFI unit and it caused random misfires. So I put the old one back in. Either I had a bad part, or screwed up the install. In either case, i didn't feel like getting back in there, so I'll leave the old one for awhile.
farley463
Oct 29, 2012 03:07 AM
97cherryblazer
Apr 25, 2012 12:53 PM
mbar
Nov 10, 2010 02:39 PM
rockislife04
Aug 28, 2010 03:31 PM
bjasonpowell
Jan 24, 2009 05:36 PM
