Misfire Returns P300
Old Apr 4, 2010 | 04:45 PM
vaportrail's Avatar
vaportrail is on a distinguished road
Default Misfire Returns P300
I had a misfire problem last at idle last fall that I was able to work my way through and thought I eliminated. The truck never idled perfectly, but with 160K on it, I didn't expect it to, just wanted it to quit throwing codes.
Fast Forward. It has returned (warmer weather maybe part of the issue).
Although it sets a P300, I hooked up a tech 2 and can watch the misfire and it is predominantly on Cylinder 5, with some other cylinders randomly missing.
Here is the strange part that I don't understand. If I rev the engine up in Neutral above 4000 rpm or so, the misfire will go away for quite some time.
I also have a CMP reading of -16 degrees. Not sure I understand whta that is, but I had read before in other posts that it shoudl be +/1 2 degrees.
Any thoughts/help is welcome. Off idle, the truck runs quite well. Accelerates well, no stumble, no hesitation. Just at idle.
rabbitthunter1@gmail.com
Jan 28, 2013 09:14 PM
rrk03300
Nov 15, 2012 10:29 PM
Dan 128
Jun 10, 2011 11:58 PM
jkatz
Apr 12, 2008 08:51 PM
kirakitty
Mar 29, 2008 12:28 PM
