Miss @ steady speeds
Old Jan 2, 2017 | 01:34 PM
rod58's Avatar
rod58 is on a distinguished road
Default Miss @ steady speeds
Engine small misses at steady speads around 1600 rpms. Put new plugs, wires, cap & rotor in. Also new fuel pump, filter & upgraded fuel injector spider. No codes. It has no problem @ idle or acceleration. I think it has to be a sensor or TPS, but I have no codes. Up for suggestions.
Old Jan 3, 2017 | 06:58 PM
Graveyard's Avatar
Graveyard is on a distinguished road
That's what mine does, if you ever figure it out I'd be very interested what you ended up doing.
Good luck.
Old Jan 3, 2017 | 06:59 PM
Graveyard's Avatar
I was kinda leaning toward the tps also but I'd be guessing.
Old Jan 3, 2017 | 09:50 PM
Rusty Nuts's Avatar
A higher end scanner can monitor misfires more accurately along with the readings from most if not all the sensors. Take the tech for a ride if necessary.
Old Jan 31, 2017 | 03:50 PM
Graveyard's Avatar
Hey Man, did you ever figure out how to correct your miss? Still dealing with mine plus it seems the idle has got a little higher.
Later
ejhuergo
Jan 13, 2016 08:26 PM
millenniumfalcon
Jan 5, 2014 08:36 AM
Patton
Mar 19, 2012 09:35 PM
Denominator
Oct 13, 2010 01:33 PM
gmyoyo
Nov 7, 2005 02:42 AM
