Missing when engine cold
Old Sep 27, 2010 | 09:15 AM
laxman21's Avatar
laxman21 is on a distinguished road
Default Missing when engine cold
Title says it all. Misses while giving light to moderate throttle when engine is cold. Once you drive a few miles, miss disappears. Misses were in all cylinders and more were in the 1,3,5 side.
Does it in the AM , but not in the PM drive home from work.
Some times there feels like there is a slight miss at highway speeds.
Old Sep 27, 2010 | 03:58 PM
step66's Avatar
Hey! Well w/o any info as to year, one can start w/ the usual culprits:check engine light on? Plugs,wires,cap & rotor,coil,module.... or it could be a minor vacuum leak that closes as the engine & components expand. Fuel economy off? Several issues can be contributing to this factor-look at the simple stuff first,then see if you can pull a code
Let us know!
Old Sep 29, 2010 | 09:51 AM
laxman21's Avatar
No codes at first.
It's a 99.
Looked like there was arching in the cap. Cleaned it out. Had a code for cylinder 4 missing next, tuesday morning.
Used wire dry spry in cap and dielectric grease on all connections and inside cap. Ran great at first no codes than seemed to develop slight miss.
Order AC delco cap and rotor as rotor looked to be slightly worn on electrode.
stevenhousden
Jul 6, 2014 05:56 PM
rckymtnrfc
May 19, 2014 04:53 PM
ravenhurst
15
Apr 26, 2009 07:53 AM
as2higpark
Oct 18, 2007 12:18 PM
fnirish
Sep 25, 2006 03:03 PM
