General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
Missing when cold
Old Sep 22, 2006 | 02:28 PM
fnirish's Avatar
fnirish is an unknown quantity at this point
Default Missing when cold
My 99 LS automatic 2wd starts and idles perfect every morning and I usually let it warm up a little before I go. After I start moving down the road for about the first 10 minutes it acts like it's missing (intermittent slugishness) at any speed and through all gears. Once it warms up to normal operating temp, it straightens out and runs fine. It will occaisonally throw the random misfire code but then usually the Service Engine light goes away after a short time. I think this may be a sensor issue but not sure which one. If anyone has seen this before and figured it out I would appreciate any info.
Old Sep 22, 2006 | 10:14 PM
Hanr3's Avatar
Default RE: Missing when cold
I would run a can of seafoam through your gas system.
Your engine should have 2 fuel injectors, one for cold starts/ideling, and the other for all other times. If the seafoam doesnt fix the problem you may need a tune up. When was the last time you did a tune up? When was the last time you replaced the fuel filter? Thats were I would start.
Old Sep 25, 2006 | 03:03 PM
fnirish's Avatar
I've only had it for about a month so It's probably due for a tune up. I sure didn't know that it had an injector just for idle and cold start. I've heard good things about the Seafoam we'll give it a try. Otherwise, it'll be tune-up time. Thaks for the reply.
stevenhousden
Jul 6, 2014 05:56 PM
laxman21
Sep 29, 2010 09:51 AM
ravenhurst
15
Apr 26, 2009 07:53 AM
as2higpark
Oct 18, 2007 12:18 PM
VORTEXV6
Oct 1, 2005 02:01 AM
