My 95 Blazer won't pass in AWD !
Old Dec 8, 2013 | 11:11 AM
Piero's Avatar
Piero is on a distinguished road
Default My 95 Blazer won't pass in AWD !
Today I went in the mountain to find snow on a pike... Problem, when I was on ice I pressed on 4WD, and I stayed in RWD....
This is a 1995 Blazer 4.3.
I can hear the relay, and the transfer case knocking, but nothing happens on the front wheels....
I've tried 4HI and 4LO.
Maybe a problem in the transfer case ?
Old Dec 8, 2013 | 11:51 AM
El_Beautor's Avatar
First place to check is the vacuum actuator under the battery tray. This receives vacuum from a switch on the transfer case and is one of the most common points of failure. The vacuum hose can become disconnected from the actuator, or the rubber diaphragm can get worn and torn. Another vacuum hose to check is the one connected to the reservoir ball on underside of the hood on the driver's side of the of the truck. It will be near the brake booster. If there is a vacuum leak anywhere on these hoses the actuator won't develop enough pressure to engage the front differential.
Old Dec 8, 2013 | 12:10 PM
Piero's Avatar
Ok thanks. So when I press on 4HI or 4LO ( in neutral ), I must see this actuator move... Does it works with engine off ?
Old Dec 8, 2013 | 12:16 PM
spittybays
Guest
Posts: n/a
Old Dec 8, 2013 | 12:32 PM
Piero's Avatar
Cool thanks ! I'll check it !
But when that actuator doesn't work, the transfert case still move ?
Old Dec 9, 2013 | 09:30 AM
El_Beautor's Avatar
When the actuator doesn't work, the transfer case should still engage the front drive shaft, but the actuator doesn't connect the drive input to the axles.
Old Dec 15, 2013 | 11:08 AM
Piero's Avatar
Well, I've fixed it ! That was the vacuum actuator hose. It was porous. Now I can go in the snow
Thanks guys for all your advices
Old Dec 16, 2013 | 01:31 PM
El_Beautor's Avatar
Great! Thanks for posting back to let us know you fixed your problem.
jimspahr@msn.com
Oct 30, 2014 08:18 PM
ntjoe
Nov 12, 2012 05:35 PM
spiritscense
May 29, 2012 11:04 PM
SteamboatReb
Apr 4, 2011 08:27 PM
maggoo702
Jul 31, 2010 01:05 AM
