MY 97 262 Vortec valve rocker arm installation
Old Sep 2, 2013 | 08:38 AM
monette999's Avatar
monette999 is on a distinguished road
Default MY 97 262 Vortec valve rocker arm installation
Dear Forum,
I am assembling my Vortec 262 engine together and having a disput with the valve lash adjustment.
how to adjust the rockers.
I see other prosposal with firing order procedure.
The GM porcedure says
Put the engine on TDC Cyl. 1 mark and then tighten all rocker nuts with 25Nm. Don´t turn the crankshaft !!
Ist this correct.
BR
Bob
The GM Service Manual is saying:
4. Apply prelube GM P/N 12345501 or equivalent to the valve rocker arm and valve rocker arm
ball bearing surfaces.
5. Install the valve rocker arms.
6. Install the valve rocker arm *****.
Important:
Once the valve rocker arm nuts are installed and properly torqued, no additional
valve lash adjustment is required.
7. Install the valve rocker arm nuts.
8.
Rotate the crankshaft balancer to position the crankshaft balancer alignment mark (1) 57–63
degrees clockwise or counterclockwise from the engine front cover alignment tab (2).
9. Tighten the valve rocker arm nuts.
Tighten
Tighten valve rocker arm nuts to 25
Y (18 lb ft).
Old Sep 4, 2013 | 11:11 AM
burned's Avatar
burned is on a distinguished road
Correct, there is no lash adjustment. Just torque to the correct spec.
Old Apr 12, 2014 | 12:41 AM
James Getter's Avatar
James Getter is on a distinguished road
question i have see it says 57-63 when titgtning rocker arms i am new to working on the 4.3 and just did head gaskekts i have a 2001 do i just tighten them to 20 ft pds or is 57-63 for the 2 timing marks on the harmonic
Uniquemel0dy
Aug 28, 2013 06:40 PM
benthm7
May 12, 2011 03:30 PM
boomtruck97
Engine & Internal
20
Aug 24, 2010 08:57 PM
stevelknievel
Sep 19, 2007 08:54 AM
ivannj
Engine & Internal
Feb 9, 2006 06:02 PM
