My Blazer just died :(
Old Nov 16, 2011 | 09:59 PM
subtlebliss's Avatar
subtlebliss is on a distinguished road
I bought it from an Advance Auto Parts and i can imagine it has a warranty if it does break. But how do i know its not something else?
I dont just wanna go through the trouble of ripping of my gas tank again if this isnt the problem
Old Nov 16, 2011 | 10:00 PM
xgiovannix12's Avatar
wish the best to you
I know it sucks to drop the tank more then once in less then a year
just follow the link i gave you and youll be fine
Would it hurt to at least run a diagnostic first to get my error?
Old Nov 16, 2011 | 10:03 PM
yes its best to diagnose it 1st
but these airtex (after market) pumps tend to provide these problems
Old Nov 16, 2011 | 10:05 PM
Alright after tom morning I will pot back results from the diagnostic and then go from there... Thanks everybody!
Old Nov 16, 2011 | 10:11 PM
ChevyBlazerChick's Avatar
Totally go forward with the diagnosing. Be prepared to get a Low Fuel Pressure code.
Old Nov 16, 2011 | 10:23 PM
Will it give me a more specific code than that because from google'ing and such I had pretty much thought I wasn't getting enough fuel pressure?
Old Nov 16, 2011 | 10:27 PM
the fuel pressure gauge will tell you if your getting enough pressure
also a leak down test would tell you if you got a leak in the system
Old Nov 17, 2011 | 12:51 AM
97cherryblazer's Avatar
97cherryblazer has a spectacular aura about97cherryblazer has a spectacular aura about
just remember as it says in the article the pump needs to be at 60+ psi with the engine running then not drop below 55 psi after 10 minutes with the truck off.
x3 on the pump being the most likely problem. With your symptoms, all fingers point to the pump, a lot of people have had the same problem. but the pressure test will tell all. keep us posted
Old Nov 17, 2011 | 01:02 PM
Well diagnostics were checked on my truck and came back with no codes. I'm about to get my fuel pressure tested and I'll check back...
