My Blazer just died :(
Old Nov 17, 2011 | 01:10 PM
  #21
bigcountry58's Avatar
bigcountry58 is on a distinguished road
Not to beat a dead horse, but there are tons of threads on this forum about the same thing...
The problem is the fuel pump, for whatever reason they all produce pressure on the low end to out of spec causing issues with the injectors.
You get what you pay for
Old Nov 17, 2011 | 01:23 PM
  #22
pettyfog's Avatar
Originally Posted by 97cherryblazer
just remember as it says in the article the pump needs to be at 60+ psi with the engine running then not drop below 55 psi after 10 minutes with the truck off.
Not quite right. The 'engine run' pressure will drop from 'key-on/eng off' because of manifold vacuum.
Should be about 60 in the key-on prime cycle.
Old Nov 18, 2011 | 09:17 AM
  #23
ChevyBlazerChick's Avatar
Hopefully you can get your money back for the Airtex pump. Its just one of those things that you either already know or learn the hard way.
... I think maybe the forums time is wonky... my post got put above subtle's even though he posted before me...
Old Nov 18, 2011 | 09:18 AM
  #24
subtlebliss's Avatar
subtlebliss is on a distinguished road
The pressure was 60 psi at the crank. Ran for a few and lost pressure. Pressure then dropped, y'all were right with the after market pump. Looks like
I'm gonna have a fun weekend.
Old Nov 18, 2011 | 09:53 AM
  #25
chris015's Avatar
ugh dude im sure it was the pump. after installing 4 of them in mine over the course of 3 months...I went ac delco. no issues.
Smack the bottom of the gas tank with a piece of lumber etc. see if it runs
Old Nov 18, 2011 | 09:55 AM
  #26
chris015's Avatar
If it was cpi,it would still need to hold above 55ish for about 5-10 minutes. Its to rule out if the regulator is leaking into the plenum. But usually if its leaking,it'll drop pretty quick.
djsgarrett
Jan 7, 2013 01:09 PM
Josh S
Jan 5, 2012 12:07 PM
j_k_auto
Jan 25, 2011 09:12 PM
91Full
Oct 3, 2010 10:10 AM
bobbye
Mar 18, 2009 01:31 PM
