My Blazer in summary
Old Mar 9, 2024 | 04:42 PM
Freeman13's Avatar
Freeman13 is on a distinguished road
Hello,
As soon as I bought my blazer I browsed this forum a lot and I came across your post among others:
https://blazerforum.com/forum/2nd-ge...lazers-103424/
Thanks to your advice I purchased Car Diagnostic Pro and an OBDII Bluetooth. So I was able to adjust the CMP
correctly it is 0.1°.
I've tested:
-spark plugs(AcDelco and news)
-Sparks OK
-Rotor and Delphi distributor cap OK.
-new coil.
-taylor spark plug wires 8mm OK
-new fuel pump
The misfires concern cylinder no. 5 and the spark plug is slightly damp.I feel that the engine is running poorly
Current codes:
p0300
p0325
p0452
Thank you for taking your time
Old Mar 9, 2024 | 09:26 PM
GeorgeLG's Avatar
Where are we on that knock sensor code? You have confirmed the 5v bias voltage at the sensor connector from the PCM? Here are some ideas on testing the sensor:
George
Old Mar 10, 2024 | 04:31 PM
Freeman13's Avatar
https://www.youtube.com/watch?v=cKTcXESPOJM
https://www.youtube.com/watch?v=1m-hftSBNwk
George
Hello,
first of all thank you for your video links.
I tested the voltage of the wire coming from the PCM and I got around 5V yes.
The sensor itself and its socket were replaced by the previous owner and are new.
So maybe it is not tightened to the specifications (19Nm I read somewhere on the forum).
I need to get a small dynamo to check this.
Old May 1, 2024 | 10:33 AM
Freeman13's Avatar
Hi everyone, I finally solved my misfire problem so I'm sharing the solution to help those who need it.
after changing the injection spider without success, I finally noticed that a wire was cut at the injector socket. this wire was the ground of my injector number 5. thanks to you George and those who helped me.
Old May 1, 2024 | 10:52 AM
GeorgeLG's Avatar
Glad your straightened out.
George
xAnarChisTx
Jul 23, 2014 09:10 PM
bkmech
Aug 4, 2012 02:59 PM
AdsoYo
Mar 4, 2011 07:24 AM
sweet-98ta
Feb 25, 2010 01:55 PM
chevcamls1
Dec 29, 2007 07:19 PM
