My cruise control no longer works? 96 LS?
Old Mar 28, 2020 | 12:24 PM
93S10TahoeLT's Avatar
Default My cruise control no longer works? 96 LS?
Very strange. My cruise control used to work fine. I get the truck back.. it now seems not to.
Maybe I had a "stored code" but.. On the next drive out.. anything I do above 25MPH I should be able to set it. Selector in the middle, yes?
Wondering if it is just a fuse .
Old Mar 28, 2020 | 05:12 PM
Check your ABS fuse
When I got my 04, the fuse was removed for whatever reason, and my cruise didn't work either. I put a fuse in it, and low and behold my cruise started working lol
Old Mar 29, 2020 | 08:50 AM
bravo99's Avatar
with the ABS fuse removed the ABS light will not light I got mine with the same thing and texted the sales kid I bought it from with a little bit of WTF about this $16 missing maxi fuse lol
Old Mar 29, 2020 | 12:08 PM
That was definitely not my experience. I removed the fuse and the whole ABS module, and the light still wouldn't go out.
Old Mar 30, 2020 | 03:49 PM
So while we are talking about the fuse, I pulled mine when I got the truck, but haven't gotten around to taking the system out, my cruise control worked up until last summer. I've owned the truck for a few years. I've debated on putting the fuse back in but haven't yet...
Old Mar 30, 2020 | 04:47 PM
cage47's Avatar
cage47 is on a distinguished road
I Know i'ts off topic from the original but regarding the ABS. The computer keeps looking for the ABS circuit. As long as the abs isn't responding (either by pulling the fuse or taking out the whole unit) the light will stay on since it is generated by the PCM. You could take out the cluster and take the bulb out.
Old Mar 30, 2020 | 05:02 PM
Thanks. I'm aware of that, and that's exactly how I "fixed" it. I'm going to stop hijacking this thread now.
93S10TahoeLT,
If you're sure it worked before, and you're sure it doesn't now, take it back to the shop so they can fix it. It's possible that a connector got overlooked or something. It happens sometimes. Give them a chance to make it right.
darknight
Aug 21, 2011 12:17 PM
02 Ted
Jan 28, 2011 03:18 PM
yarinzim
May 9, 2010 07:58 PM
ilpipe
Aug 29, 2008 06:40 PM
magnum434
Dec 27, 2007 04:48 PM
