my heat is not really that strong
Old 10-26-2007, 09:43 PM
Deezy's Avatar
Deezy is an unknown quantity at this point
Default my heat is not really that strong
in the winter time itll take like about 20 25 minutes just to get to actual hot air and when it is hot its not really that hot ?
Old 10-26-2007, 09:52 PM
Burlisonm is an unknown quantity at this point
Default RE: my heat is not really that strong
It could be one of a couple of things, could be that the thermostat is going bad, you could have a hose that is clogged or getting clogged. You could try flushing the system to see if that helps.
igot10pinitis's Avatar
igot10pinitis is an unknown quantity at this point
first off, go check your anti-freeze level!!!..
Old 10-27-2007, 01:45 AM
Chevy Lover's Avatar
ORIGINAL: Burlisonm
I agree, change the thermostat, do a really good cooling system flush and replace the antifreeze.
Old 11-08-2007, 09:22 PM
freonchill is an unknown quantity at this point
every car that i have ever driven or rode in has taken 10-20 minutes to get "WARM" in the morning when its been cold (20-40F) the night before. when i was growing up, my parents would bring blankets in the car when we rode to school in the morning.
this includes 3 fords, 5 chevy's, 2 vw
now, my fiancee's 95 honda accord - you can turn it on (in this 32F weather) and turn the heat to HIGH and wait 5-9 minutes (w/ the car idling) and it will almost burn your skin off its so hot.
Old 11-09-2007, 11:45 AM
drove to work this morning
outside temp was about 5C
got in the car, turned the heat on vent, full heat, high (4)
never got over 50mph, no fast starts, to fast breaking, 4 red lights, 10 turns.
got to work 9-12 minutes later
the heat was "warm" to the touch but not hot.
it didnt get "warm" till about the last minute or two (which was the only part of the trip where i was idling for more than 30sec in stopped traffic.
the engine temp showed about half way between 100 and 210 (210 is the top of the dial i think) when i turned off the car.
Old 11-10-2007, 02:16 AM
I have done chemical flushes ( takes about 3 hours),and then changed the thermostats on a few S10 blazers in the past. When I was done, the hot airfrom the ducts was so hot that I couldn't keep my hand if front of the air vents.
Old 11-10-2007, 10:29 AM
AJBert's Avatar
AJBert is a jewel in the roughAJBert is a jewel in the roughAJBert is a jewel in the roughAJBert is a jewel in the rough
Run the engine for about 30 minutes and allow it to get up to operating temperature. Even with it being cold out the temp should be up around 190-210 F. If it is getting to that temp and you still are not getting good heat a flush is in order. If it is not getting up to temp a thermostat is in order. From what you've described, it sounds like everything is working fine to me. You are getting to work at about the time the engine is up to temp.
Old 11-19-2007, 12:47 PM
havrelm1 is an unknown quantity at this point
Clogged heater core?, once at operating temp feel the return hose and see if it's super hot or just as warm as the temp in the engine bay. Both should be hot if the coolant is flowing through. My return line is no hot and I have NO heat whatsoever, I'm gonna try to flush it out by disconnecting both lines and running the hose through it, I dont have $ for a new one right now.
Old 11-20-2007, 05:29 PM
megatrack is an unknown quantity at this point
I had the same problem lastwinter, I flushed the heater line and now it is so hot I can't keep my hand there. When I flushed itI saw some crap coming out of there for about 2-3 seconds after the water was clear. doesn't take much to clog the lines.
AJ
cjw4050
03-23-2014 10:07 AM
serrasalmus
06-12-2012 05:57 PM
EuroGoldLS
05-27-2007 11:09 AM
ivannj
01-25-2006 10:42 PM
hollisterdj
12-01-2005 03:22 PM
Quick Reply: my heat is not really that strong
