My transmission is leaking fluid..??
Old Jun 27, 2016 | 05:40 PM
RSDEVIL's Avatar
RSDEVIL is on a distinguished road
Default My transmission is leaking fluid..??
The converter became lose from a towing trip. (I towed another Blazer home to fix up mine haha go figure...???)
At first I thought I blew the motor or spun a bearing the noise has so shakey. Turns out the converter bolts were lose.
Tightened them up and thought all was well again. Took her for a ride and she started blowing ATF after about 20 miles or so EVERYWHERE.
Limped her home, filled her up w fluid, let her run.... And I'm noticing fluid dripping from btwn the converter and transmission.
****. I'm pretty sure I know the outcome. Any food for thought...??
Old Jun 27, 2016 | 06:00 PM
odat's Avatar
best guess you egged the holes in the flex plate and the torque converter isn't running square with the flex plate and its prob wobbling in the front seal or eating the seal
Old Jun 27, 2016 | 06:07 PM
Racer_X's Avatar
Racer_X is on a distinguished road
Most likely the input shaft seal was damaged by the vibration from the loose flex plate->converter botls.
The bad news is you have to separate the transmission from the engine to repair this.
The good news is the "input shaft seal" (AC/Delco part # 8667035) is only a couple bux.
While you have it apart, you'd be a fool not to replace the crankshaft rear seal and the other external seals on the transmission.
No, you won't need a "rebuilt/remanufactured" transmission.
Definitely check the flex plate for wear around the holes where the bolts go. If in doubt, a new (or even used) flex plate is a good idea.
BTW, many Jeep 4.0L engines have been replaced because of "bearing knock" which was actually loose flexplate bolts.
Also, use blue loctite on those bolts when you put it back together.
Last edited by Racer_X; Jun 27, 2016 at 06:12 PM. Reason: added comment about flex-plate.
Old Jun 27, 2016 | 06:19 PM
Racer_X's Avatar
Adding to my previous comments, during the repair of the input shaft seal, it would also be an excellent opportunity to drain/fill the transmission and clean the valve body and replace the filter and easily accessible internal seals.
After this type of complete hydraulic repair, it's generally safe to go on a 30,000 mile ATF drain/fill and filter replacement regimen, even if the thing has been neglected for 100K+ miles.
Old Jun 28, 2016 | 08:48 AM
Tajohns34's Avatar
If I were to pull it apart I would just get a new flexplate just to be safe.
janddcunningham
Apr 17, 2012 09:51 PM
grayfort
Jul 29, 2011 06:31 AM
Mjseyler
Jan 5, 2010 12:44 PM
Swain
Aug 27, 2009 09:14 AM
fruccoman
Feb 15, 2006 07:08 PM
