mysterious transmisssion leak
Old May 2, 2009 | 11:03 PM
pajama01504's Avatar
pajama01504 is an unknown quantity at this point
Default mysterious transmisssion leak
1998 4L60 E 4 wd...has anyone experienced transmisssion fluid loss with no apparent cause.
I lose app. 1 quart in 1,000 miles, but there is no evidence of the leak except on the dipstick.
A leak of this magnitude should show drops when parked, or oil in the engine coolant.
Old May 3, 2009 | 02:16 AM
bandidolenny's Avatar
Check the fluid level in your transfer case to see if it's overfull. Could be going there.
Old May 3, 2009 | 12:53 PM
65longroof's Avatar
65longroof is an unknown quantity at this point
If the T-case is full you will need to replace the input seal on the T-case. I had the same problem with my 95 and with a 90 suburban.
Good luck
Old May 3, 2009 | 02:36 PM
Same suggestion from me as both of the previous replies. Check the transfer case level by pulling the fill plug (upper one). If fluid pours out, the front seal is bad. Hopefully you do not have fluid in your vacuum system...
Old May 3, 2009 | 10:46 PM
65longroof's Avatar
I got fluid into my vac system from this.....no fun to fix...almost worse then fixing the seal.
Old Jun 27, 2009 | 04:40 PM
Denominator's Avatar
Denominator is on a distinguished road
what did you do to get the fluid out?
lityjohn701
Mar 22, 2013 09:23 AM
lostrealist
Oct 12, 2012 07:07 AM
crazyls2
May 11, 2012 09:20 PM
MTopper
20
Dec 15, 2011 12:28 AM
vermillion2
Jul 1, 2009 08:37 PM
