Mystery Fuel Tube (2003 4-door)
Old May 21, 2010 | 11:57 AM
FredEx's Avatar
FredEx is on a distinguished road
Default Mystery Fuel Tube (2003 4-door)
I was installing a trailer hitch my 2003, 4WD, 4-door, and broke a plastic tube connection labeled "Fuel" that attaches to a box behind the left rear wheel between the fender and the frame. The box is about the size of an ammo box, and has several lines/tubes coming out of it. The tube connection that I broke attaches to the rear of the box. No fluid came out. The connection is an actual flange component of the box's casing meaning the entire box casing may need to be replaced.
I've not been able to find any information in a Chilton manual or online. Can someone tell me what this is, what it does, and how critical it is to fix the broken connection?
Thanks
Old May 21, 2010 | 09:41 PM
ZR2Daddy01's Avatar
ZR2Daddy01 is on a distinguished road
http://repairpal.com/charcoal-canister.
Try this site hope it explain enough.
Old May 21, 2010 | 11:09 PM
Yep, it's the charcoal canister. If you can, just epoxy the break back together. You have to be sure that you seal up the system or you will get a check engine light and possibly fail your inspection if your location has them.
FredEx
Nov 4, 2013 02:23 PM
DaddysBlazer
Apr 12, 2012 09:36 PM
gravest
Sep 7, 2011 12:18 PM
biglfla
Mar 24, 2011 06:19 AM
Browntrouzerz
May 23, 2010 06:44 PM
