Mystery keyless entry problem
Old Dec 16, 2025 | 05:02 PM
C210M's Avatar
C210M is on a distinguished road
Default Mystery keyless entry problem
My keyless entry works as normal with outside air temperature in the upper 70s or above. Cooler temperatures the keyless entry is inoperative. New key fob, new batteries. Any help will be greatly appreciated.
Thank you.
Old Dec 16, 2025 | 06:30 PM
I'm not too familiar with this system, but is the error correlated to temperature or humidity?
And when you say "inoperative" is it that there is no indication of the security light even coming on on the dash when you depress the fob button or any noises as if the locks are trying to unlock?
Old Dec 17, 2025 | 07:19 PM
LannyL81's Avatar
Give this a try:
Open the key fob, carefully!
Use some 90% alcohol and Q-tip, clean the circuit traces under the push buttons and wipe off the push buttons as well.
Take a good ole' #2 pencil and go over the ends of each push button.
Put key fob back together, see if it works any better.
C210M
Dec 1, 2023 04:00 AM
djsuperman
Nov 27, 2010 10:11 PM
midnightbluS10
Aug 8, 2009 08:55 PM
classklown90
May 10, 2009 07:11 AM
nofear17bmx
Jan 26, 2007 03:35 PM
