name of front section of body, 99 blazer 4x4 4dr?
Old May 26, 2013 | 10:22 PM
drealot's Avatar
drealot is an unknown quantity at this point
Default name of front section of body, 99 blazer 4x4 4dr?
Had a collison, pushed in the drivers side fender, bumper, broke the grille & also bent the front drivers side corner of what looks to be the frame or underbody? the section that the fenders, grille attach to? between the radiator & grille, whats this part or section called? & can it be replaced? or should it be staightened?
Old May 26, 2013 | 10:40 PM
richphotos's Avatar
Core support.
Old May 26, 2013 | 11:47 PM
WitchingHour's Avatar
WitchingHour is an unknown quantity at this point
It can be replaced easily enough. You'd actually replace the core support if you were to say, put a 98+ grille and lights on a pre-98 vehicle. You'd probably be better off replacing it than to try straightening it out. Check your local pull and pay yards.
Old May 30, 2013 | 05:56 AM
builder125's Avatar
builder125 is on a distinguished road
its called the nose clip or front end clip,hope that helps you .
honky
Lifting Tech
Aug 6, 2011 04:12 PM
Moores12345
Lifting Tech
Jun 28, 2011 02:22 PM
Blazerstu
Oct 9, 2009 07:14 AM
BLAZIN
Mar 2, 2007 01:11 AM
