name this liquid?
name this liquid?
I found this under my front axle/ oil pan area. im not 100% sure if its coming from my truck or not because theres a similar grease type stuff (im assuming) under my stepdads rear axle area of his 03 mercury mountaineer
if i had to take a guess....axle grease ? if so is this a common problem? where/ what should i check
thanks in advanced!
thanks in advanced!
yesterday a high of 35...today its 49. so i mean its up and down...the coldest it has gotten was 20 but that lasted a week lol. and i got a small oil leak too but i think its because im missing an oil pan which is in the mail lol
check your oil and tranny fluid. from the dip stick and make sure they are not white also...that looks like an oil and water mix...bad sign....if your fluid are not white then I got nothing...and check radiator fluid,,,
ive noticed this spot for a few months, i usually park there but recently my stepdad has a few times recently..hoping it aint mine for once lol
idk if the picture does it justice, but its only the cream colored thick (grease maybe) no black/gray indicating oil is in the mix
the black already down on the ground is existing oil thats been there for years lol
I agree here. You could've got water in your differential. That's what and oil water mix looks like. You could've then go a leak in it, so it's showing up in your driveway. Check the front and rear differential for droplets of the same looking stuff. You can also take out the fill plugs and see if it comes pouring out, or stick your finger in there and get a sample and see if it's the same creamy/milky/carmely color. You can check the mountaineer if yours checks out.
