Need another frickin opinion
Old Dec 15, 2008 | 12:00 PM
Kage0113's Avatar
Kage0113 is an unknown quantity at this point
Default Need another frickin opinion
I was replacing my rear brakes yesterday afternoon. turns out the shoes were fine, but one of the drums must have been warped or something cause it was getting dug in causing my problems. Anyway, before yesterday, I had never had that rear tire off. The moron before me cross threaded the lug nut, so I snapped off my stud[:@] So I could try and pound it out with a hammer and take the chance at bending things, or i can drain my differential and undo the bolts and stuff to my axle to pull the whole thing out and have someone machine press out the old one and put the new one in. Anyone had any experience with this? thanks in advance
Old Dec 15, 2008 | 12:03 PM
Byte Stryke's Avatar
Byte Stryke is an unknown quantity at this point
Default RE: Need another frickin opinion
"If you don't have the time or means to do it right the first time, where will you find the time and the means to do it over again?"
Just my 2 cents
Old Dec 15, 2008 | 12:56 PM
rriddle3's Avatar
And I'm sure that was a big help to him.
Instead, here's a thread with plenty of information.
Old Dec 15, 2008 | 02:45 PM
WolfPack's Avatar
It probably wasnt the 'moron before you'. It was probably your lack of maintenance. The lugs rust to the studs if they never get moved.
I snapped 2 studs on my front wheel after getting it submerged in some muck...I even pulled off the wheel and cleaned it all out, just not enough.
But..its not really that hard to get the stud out. Granted I have the discs up front, but once the rotor is off and you see the end of the axle (or whatever the name for that flange the studs go through). The stud can just be hammered out. Then to pull the new one back in, just flip the lug nut over (so the flat side is against the axle), and tighten the hell out of it. It pulls the stud right in.
I did both both of my studs, and coated all the remaining studs in PB blaster to avoid future breakage, in about 15 min (also including tracking down that pesky 18mm wrench).
chunkster5979
May 28, 2012 11:15 PM
97Bravada
Jan 20, 2010 07:38 PM
trinaxt
Jan 29, 2008 01:10 PM
Chevy Lover
Mar 6, 2007 11:56 PM
knightrider79
Sep 6, 2006 12:35 AM
