I need an another opinion
Old May 25, 2012 | 08:08 PM
chunkster5979's Avatar
chunkster5979 is on a distinguished road
Default I need an another opinion
I need to buy new tires for my 1985 k5 blazer. It's sittin on old 31s right now that need replacing. should i go up to 33s and if i do any suggestions on what to get. Also my dad dad was telling me if i went up on size the gear ratio would change making the truck more sluggish in low end. How would i compensate the gear ratio to make up for the bigger tires? Any help would be nice.
Old May 25, 2012 | 08:29 PM
abig84's Avatar
you would have to change the gears inside your axles. probably upwards of $1000 or more if you bring it to a shop. probably cheaper to swap axles if you can. i had a 84 k5 blazer that had 273 gears and 35 inch tires when i got it. i bought a set of 373 axles for it and it really helped.
so technically you can put 33s on it. also if the truck is stock those tires are probably going to rub. another k5 i had had 33s and a 2inch body lift and the tires would rub on tight turns
Old May 25, 2012 | 08:42 PM
No its not stock. Its already got a four inch lift on, so its got plenty of room in it. and i think it was like 310 ratio with the 31s. I was told 373 would be good with the 33 in. like you were saying, I just didnt know how i would go about that. And i can do the work myself, but a little more HP wouldnt hurt either haha.
Old May 26, 2012 | 12:35 AM
abig84's Avatar
i got two trucks with 373s and 33 inch tires and they work just fine. installing gears is a pretty complicated if youve never done it before. have someone help thats done it before. they have to be set up a very specific way. thats why i just swapped axles. its actually faster and cheaper to do it that way.
Old May 26, 2012 | 05:31 AM
newguy's Avatar
Put the bigger tires on, if nothing brakes your good, if it does then change it. If your not beating on it to hard, you should be ok. Just my opinion
Old May 26, 2012 | 07:44 AM
I wouldn't mind either way I did it. I'm trying to learn all the tricks of the trade and after summer ill have college automotive shop to work out of. But nothin beats learnin from your garage
Old May 26, 2012 | 10:09 PM
My '74 K5 has 3.73's & 33x12.5 MT's and it cruises down the highway just fine. I'm not sure I would want to have an over drive transmission with 3.73's & 33's though.
Old May 27, 2012 | 12:23 AM
duxtoyz's Avatar
duxtoyz is on a distinguished road
ya. if u dont mind running in higher rpms do 3:73 with 33s. but if u wanna keep the rpms down and mpgs up go with 4:56s and 33s, if u have o/d. ul keep the mpgs up, the rpms down, the low end power and all around good quality or ur truck. not too much wear and tear and heating of the transmission either. but if u dont have o/d then id do what everyone else is saying. personal opinion, with 33s id go at least 4:10. also, what motor and tranny do u have?
Old May 28, 2012 | 06:34 PM
To Duxtoys I have 305 5:0 motor and the r4700 transmission and if it helps I can find out the transfer case to I just can't remember off the top of my head right now
Old May 28, 2012 | 11:15 PM
duxtoyz's Avatar
then u have od and plenty of power to turn 4:56 with 33s and keep ur rpms down. but if u have acess to 3:73 easier then go with those. theyd work too. but in my opinion 4:56 would be way better. save u a lot of headache later. if ur gonna do sumthing like that, do it rite the first time.....thats my motto.
97Bravada
Jan 20, 2010 07:38 PM
Kage0113
Dec 15, 2008 02:45 PM
trinaxt
Jan 29, 2008 01:10 PM
Chevy Lover
Mar 6, 2007 11:56 PM
knightrider79
Sep 6, 2006 12:35 AM
