Need better brakes
Old May 2, 2008 | 10:04 PM
Brocktward's Avatar
Brocktward is an unknown quantity at this point
Default Need better brakes
I have a 95 and the brakes arent cutting it, I would like to convert the rear to disc brakes, is it possible to swap out withparts from anewerBlazer with rear disc brakes???
Fixed a whoops.
Old May 2, 2008 | 10:20 PM
WolfPack's Avatar
Default RE: Need better brakes
I believe you need a new axle with discs, not just a simple swap of parts to drop the drum and add the rotor[&o]
Old May 2, 2008 | 10:21 PM
Scooterewski's Avatar
Scooterewski is an unknown quantity at this point
What are disc brakes? Are those the ones that stay on the whole time you're driving so the person behind you has absolutely no clue when you actually are stopping???LMAO!!! I'm not too sure about the part compatibility....what kindof pads are you runnin in the front? You could also check that the adjuster on your rear drums and make sure that they aren't stuck....
Fixed another whoops.
Old May 3, 2008 | 03:02 PM
Brocktward's Avatar
I have replaced the front 2 times and the back once in the last 5 months, the back do tend to get stuck so I adjust them often, I drive it 200 miles a day loaded full of heavy tools and I live in a hilly area and drive stop and go Los Angeles traffic, I think 4 wheel disc would be better if it is as easy as swaping the rearend and rebuild the pistions.
poertsch
Apr 23, 2016 01:05 PM
mowermechanic
Jan 31, 2012 09:01 AM
chris015
Engine & Internal
Jul 25, 2011 09:13 PM
218persuader
Aug 20, 2010 06:11 PM
98Ltblazer
Aug 15, 2010 08:07 PM
