need engine...
The worst thing you will run into is the bell housing bolts. I long extension will go a long way. The driver side upper is a real peach. you will have to drop the x member for the tranny, jack up the body, or do as I did and drill a hole in the floor under the pedal. Make sure you remove everything from the front to clear the support.
k guys well just went and picked the new motor up it was out of a 2001 and had 38454 miles on it paid 500 bucks thought that was an awesome deal... didnt really start tearin it apart yet got the radiator off n that bout it.
While you have the replacement engine out, go ahead and replace all the gaskets. I did and have not seen a drop of oil. Much easier out of the truck.
Great deal on the engine. I paid 425 for a 67k engine. Had to drive an hour to get it but it was clean.
I know you have a 1997 Blazer .The replacement Engine is an 01 you got. The 2001 engine has a (2) wire Knock Sensor and you will need to Drill and tap the hole Larger to the ole style (1) wire sensor you have from the 97 engine . When you ask about engines you said a 1998 or 2000 for a replacement not a 2001 in your First Post Remember? Better Check it out. Hope this helps T.J.
That should be an *if* it has a 2 wire sensor. Good call, but there were two different knock sensors for this year. It just takes drilling and tapping the back of the block to switch between the two.
ok cool thanks for the info ill look into that. well i was originally getting a 2000 but i found this and it very well could be a 2000 the guy didnt know the year he said it a 00 or 01 i just figured that they were the same anyway i liked this engine cause it was closer and it came with everything the bracket on the front of engine alll the pulleys ac and alt even the fan. but yea ill look at the knock sensor and see what it is.where is it located? it on the back right?
Ok just wanted to point this out, It would Suck get it in and ...WHAT ,,,,Wrong Knock Sensor, And Yes the big "IF" comes into play . Yes the sensor is on the Back of the engine, if you are looking at the engine right side of the Distributor on the block. Good Luck T.J.
well didnt have alot of time this weekend to work on the blazer like i thought i was going to, but i think the engine is almost ready to come out. i got everything but the top driverside bellhousing bolt and the motor mount bolts. think ill just take the crossmember off and lower the trans to get to it idk. hopefully it will be out sooon though
worked on it more tonight after work. took forever to get that top bolt but i managed to get it by taking the cross member out and getting it from the top of the engine with a flex head gearwrench sucked but least its out. i was lifting it out and the bolt thaat i was chain to snapped so i got another bite but left it for the night hopefully it will lift right out tomarrow night. if it wasnt for bad luck i would have any..
Stansfield
07-04-2010 06:54 AM
N.alaska_blazer
02-23-2009 01:31 PM
loppy crimp
09-11-2008 08:31 PM
DBlaser_ca
08-02-2007 04:44 PM
