Need Fuel Pump Help
Old Jun 27, 2009 | 04:35 PM
bandidolenny's Avatar
Do you have a check engine light? If you pull the fp relay and jumper the "load" wires and the pump runs then the pump is not the problem. The relay gets a signal to turn on from the computer... the computer comes on with the ignition switch (that's the simple version). Sounds either like a computer or ignition switch problem. Be sure to check the ground wire to the computer.
Old Jun 27, 2009 | 08:09 PM
pinetopfirefighter's Avatar
pinetopfirefighter is an unknown quantity at this point
Thanks. That makes sense. I am going to let him know first thing Monday morning.
Old Jul 8, 2009 | 03:52 AM
ZR2SuperDiggers's Avatar
ZR2SuperDiggers is on a distinguished road
Check the ground block that hangs under the back bumper with 11 wires hanging from it and look for corrosion or anything that doesnt look normal
BouncingRadical
14
Nov 27, 2015 12:30 AM
cide
Nov 7, 2009 01:26 PM
upblazer95
Mar 8, 2009 07:15 PM
Lckyctch
Dec 30, 2007 05:38 PM
mytruck2
Dec 13, 2006 04:50 PM
