Need Help asap
Old Feb 17, 2008 | 01:08 PM
myol blue4x4's Avatar
myol blue4x4 is an unknown quantity at this point
Default Need Help asap
Ok, the other day my blazer had some wiered electrical problems. It all started when driving with my friend, we were at a red light and my cd player just shut off. Around two hours later it did the same thing, then an hour after that it did it again and needed to have the stations reprogramed. Later that night I was turning and my blazer just shut off, everything except the headlights. This morning I tried to start it but only to find out that my blazers battery is totally dead, if possible can you please let me know what you think the problem it, thanks.
Old Feb 17, 2008 | 01:09 PM
SSBlazer's Avatar
SSBlazer is an unknown quantity at this point
Default RE: Need Help asap
Check the wires at the starter.
Old Feb 17, 2008 | 01:44 PM
dBsound's Avatar
dBsound is an unknown quantity at this point
Could it be the alternator, completely crapping out?
On my 95, within about 10 minutes, mine went from running perfect, to barely even able to idle, or run any accessories. Made it to the Autozone parking lot(it was a Sunday, so no garages were even open). They tested the alternator, and it had completely died. Thank god I had enough tools to change it there, because there's no way it would've made it home.(I guess because there wasn't enough juice left in the battery, to run the computer).
Old Feb 17, 2008 | 02:08 PM
Is this an aftermarket stereo?
Old Feb 17, 2008 | 06:12 PM
Yes it is a aftermarket radio, its a flip out touch screen but I thought when I got it, it would be wise to have a audio shop install it so I did. Could the wires on the starter cause just the radio to turn off though?
Old Feb 17, 2008 | 06:15 PM
I'm betting that there is a wiring problem. Most likely a main power wire with the insulation rubbed off. If I were you, I would pull the stereo out and have a good look at the wiring as far back as you can.
Old Feb 17, 2008 | 06:18 PM
Oh alright, thanks very much for the help, so does it seem like a wire is grounding or something?
Old Feb 17, 2008 | 06:41 PM
2002XTREME's Avatar
2002XTREME is an unknown quantity at this point
I go with what Kyle said... your altenator was taking a vacation without your consent and it killed the battery...
Old Feb 17, 2008 | 06:59 PM
That isn't what I said. It is a possibility. How long ago was the stereo installed?
Old Feb 17, 2008 | 07:17 PM
It was installed over 6 months ago
