Need Help asap AGAIN
OKAY!!! so back to square one,have a 97 s10 blazer new fuel pump in, new filter, blazer started up, went from 20 PSI to about 66 PSI, started, went down to 40, got lower after that, it isnt showing a code, we are thinking a restriction in the fuel line, what do you guys think, i need help asap, im going to my friends to work on the truck again, so yeah =) thanks
If the fuel pump is new, did you buy a quality AC Delco pump or a cheap airtex pump? It also could be the FPR at fault, but you need to do the fuel pressure diagnosis as Swartlkk said. It could have been the FPR this whole time and if you replaced the fuel pump without knowing, if that was the case, you are just throwing money into it without knowing the problem and hoping for a fix
What did the diagnostic trouble shooting chart lead you to? If you are losing pressure, you have a leak. It could be a bad line, FPR, or check valve on the pump.
And please have patience. Wait 24 hours for someone to respond. Use that time to search. You are not the first one to have this problem and I know that the information is out there.
The FPR and spider assembly is located between the upper and lower intake, you will have to remove the black upper intake to gain access to it, once you have that removed you can hook the lines and electrical back up and key on to prime the system and look for leaks. Also keep and eye out to see which side seems to be clean, washed as that will tell you that there is a leak. Also while you are down that far, it may not be a bad idea to replace the lower intake gasket as well
You seem to have missed one of the questions I asked... Did you replace the pump with a quality AC Delco or Delphi pump, or a cheap Airtex pump?
ok i REDID the fuel daignosis char, came up with FPR this time,)first and second time said leak and Fuel pump, i mustve got mixed up last 2 times
Last edited by swartlkk; 07-04-2010 at 11:09 AM. Reason: *Consecutive Posts* - Please use the edit feature to add more information to your post if another member has yet to reply.
okay, replaced the FPR, STILL sits at 15, my dad bought a cheap offbrand pump (not AC Delco/delphi) so it might be the fuel pump, im going to switch the delphi fuel pump back in and hopes it goes up...........$120 bucks at the auto store
