NEED HELP ASAP!!! water leak inside!
Hey guys i really could use some help. I have done a lot of research and have not been able to answer my exact problem.
i have a 2000 chevy blazer lt 4 door 4x4.
my drivers side carpet is soaking wet. it is water not antifreeze. i have found the water leak in front of the parking brake, there is a hole in the oem sealer. i took the little part of the cowl off, making the hood hinge visible. poured water ontop of the hinge and bolt area, and then water pours into the cab through the hole. Now my problem is i cannot seam to pin point where the water is entering from the top.
any ideas would be greatly appreciated!!!
