Need help buying MAF Sensor
Old Nov 12, 2012 | 08:36 AM
lannon_j's Avatar
lannon_j is on a distinguished road
Default Need help buying MAF Sensor
Don't know too much about mass air flow sensors, and I need help deciding which one to buy. The guy at AutoZone said they were expensive, and sites have them listed anywhere from $100-200, but I saw them listed on eBay for around $60. How much should a good MAF sensor cost? And lastly I don't know the difference/preference between the Plastic and Metal housing. Thanks
2001 Blazer 4.3 4WD
Old Nov 12, 2012 | 09:23 AM
spittybays
Guest
Posts: n/a
Due you know yours is really broke, is the platinum screen inside torn up? They can be cleaned with MAF cleaner and that will get most of them up and running.
Old Nov 12, 2012 | 09:27 AM
lannon_j's Avatar
I'm not sure if its broken or not, but the engine light came on (not on anymore though) i had it scanned and the problem was the MAF sensor, and the PVC valve. Im hoping a new MAF will help with the delayed acceleration.
Old Nov 12, 2012 | 10:15 AM
spittybays
Guest
Posts: n/a
IMO get a can of MAF cleaner and follow directions. It should not take more than half an hour and almost no tools. Make sure its MAF cleaner. If you want to you can unplug the MAF and see if it makes a difference. I believe the computer takes it to a default mode but since you tossed a code why not clean it anyway. Think the stuff is like seven bucks.
Old Nov 12, 2012 | 10:20 AM
mrspeedy69's Avatar
mrspeedy69 is an unknown quantity at this point
Yeah definitely try some MAF cleaner. Mine was throwing a code for it and had bad acceleration. Took out the sensor and cleaned, ran like a totally different vehicle. It's super easy to do and will only take you about 10mins. Just be careful not to bend or brake the little wires inside the MAF sensor.
Old Nov 12, 2012 | 10:30 AM
chris015's Avatar
half the time they just get dirty. clean it.
Old Nov 12, 2012 | 10:50 AM
lannon_j's Avatar
Sounds good guys, I'm gonna give it a go, thanks for the input!
Old Nov 12, 2012 | 11:35 AM
rriddle3's Avatar
This thread will walk you through it.
Old Nov 12, 2012 | 12:04 PM
Diaita's Avatar
If you are running a k&n filter or similar reusable filter(one you put filter oil on) they make a mess of your maf sensor. Get one from the junk yard. They are cheap, rarely fail, and it's a factory part.
Old Dec 11, 2012 | 02:13 PM
Jonboy's Avatar
Jonboy is on a distinguished road
K&N filters with oil can cause MAF issues???
I put one of those in...followed the instructions to the letter.
I have been experiencing MAF issues (verified by a friend who works for GM dealership and hooked it up to a computer) - this was AFTER I used 1.5-2 cans of CRC MAF sensor cleaner on it....
What I don't remember was whether the MAF issues started before or after I added the K&N.
Anyone else have experience with K&N causing MAF issues?
Thanks,
Jonboy
blank
Headers, Intake, & Exhaust
May 14, 2013 07:40 PM
ChrisRapp
Apr 17, 2011 02:45 PM
khalid_20879
Mar 27, 2006 11:16 AM
MikeForS
Mar 25, 2006 04:43 PM
ivannj
Feb 11, 2006 03:00 PM
