Need Help with electrical problem.
Hi guys new to the forums and seeking some help.
I have a 2001 Bravada with 130,000 miles that is dead every morning due to a drained battery..
When I shut my rig off I noticed the "red battery light" and the "odometer" stay lit and never shut off..
Not sure if that is thats what's draining my battery or why these 2 things stay lit up either..
I also noticed when I open the drivers door the security light is flashing and the "buzzer" or whatever you call it is chiming..
and when you start it and put it in gear the doors lock but when you put it in park and shut it down the doors do not unlock you have to do this manually..
Could all these problems be from a faulty ignition switch or??
Any help would be great thanks in advance.
Dustin.
Dustin.
Check to see if all these problems use the same circuit if they do you might have a wire shorted to ground or power. If you are having locking issues with your doors check the wiring going from the vehicle into the door. Those wires that a lot of abuse over the years.
JoSHN
09-14-2012 04:56 PM
my
03-09-2009 03:36 PM
