need help with fuel problem please
Old Apr 17, 2009 | 08:17 PM
pug817's Avatar
pug817 is on a distinguished road
Default need help with fuel problem please
I have 97 blazer with 4.3 it was hard to start it would run good once it started now it wont start unless you use stating fluid it has good pressure at lines where it goes into fuel meter body any have any ideas that could help figure whats going on any help would be greatly appreciated
Old Apr 17, 2009 | 08:44 PM
bandidolenny's Avatar
Have you actually measured the fuel pressure with a pressure guage? Do you hava a check engine light on? Do you have any stored codes?
Could be a cold start sensor but at this point i am just guessing without more info.
Old Apr 17, 2009 | 08:55 PM
pug817's Avatar
yes it was measured with a pressure gauge its in spec no codes or check engine light
Old Apr 17, 2009 | 09:15 PM
rriddle3's Avatar
It only takes 3 things to start an engine:
1. Air
2. Spark
3. Fuel
We assume the engine is getting air and you say that the fuel pressure is 'in spec', so what does that leave? Spark. Have you verified that you are getting fire to all the cylinders? And just to satisfy curiosity, do you remember what the actual fuel pressure readings were?
Old Apr 17, 2009 | 10:05 PM
pug817's Avatar
its got spark it will run on starting fluid pressure was 59 psi key on not running
Old Apr 17, 2009 | 10:20 PM
You may have a problem with the spider. Anyone else got an idea?
Old Apr 18, 2009 | 09:45 AM
Classic symptom of low fuel pressure. For the CSFI system, 59psi is too low for the poppet valves to spray correctly. Key on, engine off, fuel pump running, pressure must be 60psi to 66psi and remain above 55psi for 3 to 5 minutes after the pump shuts off.
Jerry.rm125
Sep 4, 2014 02:45 PM
MyBlazerSucks
Jan 5, 2012 12:02 AM
laidblazer
15
Jul 1, 2010 10:45 PM
rogggg1020
Nov 11, 2008 08:05 AM
