Need help ID'ing a sensor and AC problem
Old Aug 17, 2009 | 06:10 AM
Renthorin's Avatar
Renthorin is on a distinguished road
Ok. I will give that a try when I get home from work today :-)
Old Aug 17, 2009 | 05:33 PM
red blazer's Avatar
red blazer is on a distinguished road
Well that didnt last long, it worked all the way to work but stopped half way home. I stopped at a local chevy dealer and ordered an accumulator switch $40.00 and they do not stock it and will be in tomorrow.
Old Aug 17, 2009 | 05:50 PM
Renthorin's Avatar
I hooked mine back up and was all set to try the tap test...wouldn't you know it...runs just fine at the moment.
I will leave it hooked up and if it freaks out again I have my jumper in the center console ready to bypass the switch again :-)
Did they say what they want to evac/recharge the system?
Old Aug 17, 2009 | 06:13 PM
red blazer's Avatar
I am going to call a shop tomorrow and see what they want to evacuate my system and then recharge it back up. You wouldnt think it would be much.
Old Aug 17, 2009 | 07:14 PM
Renthorin's Avatar
I suspect it is 150 bucks or so....
Old Aug 18, 2009 | 04:29 PM
red blazer's Avatar
Renthorin, I just put my new switch in and it took me about 1 minute. It screws into a shrader valve, no need to evacuate the system. Thanks for everything. $40.00 fix isnt bad.
Old Aug 18, 2009 | 05:43 PM
Renthorin's Avatar
That's great! :-) So when you unscrew the sensor on the side of the silver container (love my technicality) it doesn't bleed the system?
Just want to make sure we are talking about the same sensor as the one in my picture.
Did that fix the problem?
Old Aug 18, 2009 | 07:14 PM
red blazer's Avatar
Yes we are talking about the same sensor or GM calls it a switch and yes it is the one in your picture. The problem is fixed and again thanks alot for your help. Oh, the system will not bleed down on you, your good to go.
Old Aug 18, 2009 | 07:53 PM
Renthorin's Avatar
Thanks Red I will go get a switch tomorrow.
OxFORD-ZR2
Feb 14, 2018 04:42 PM
g4mbl3
Dec 8, 2008 04:39 PM
UrbanOffRoader
Nov 14, 2006 02:12 PM
prototype80
Jul 25, 2006 12:26 AM
blazin97
Mar 26, 2006 03:01 AM
