Need help please.
Do it three times in a row. Turn the key on and try to start it - it should try to start and stall, leave the key in the on position. When the light goes out turn the key to the off position for 30 seconds. Try to start it again (won't start) then leave the key in the on position until the light goes off then...... It should start after going through the routine the third time. Also if the problem is the Passlock you should see that small "try".
So I want to give you a sincere thank you for all your help.
I tried the relearn (it was a tad different instructions) from another forum and it didn't work sure glad you could help me out as your instructions worked like a charm.
So what I replaced was the whole thing switch harness,key tumber, and tumbler box bought it as a whole unit so I just replaced everything..
to do this I had to remove the steering wheel unhook the airbag etc..
Now every problem I explained in the beggining is fixed everything functions like new.. Only thing I noticed is my airbag light stays lit solid now.. Do I need to reset the sir or something to get this light off?
Anyhow I still can't believe i got the Bravada going I'm very happy.
Thanks again.
Dustin.
There was around disc behind the wheel that needed romoved and it said to rotate till the window was yellow which I did.. I'm wondering if I made an error there maybe?
I'll look into some more but for now atleast I have my wheels back so I'm happy.
opposedforces
09-01-2011 02:59 PM
